Pour résumer :
[Plugin Tiers][Sujet Principal] Kodiasgui - Utiliser Kodi comme interface
Pour échanger sur les plugins classés en catégorie "Multimédia"
beber53
Re: Plugin Kodiasgui - Utiliser Kodi comme interface de con
Message par beber53 » 25 janv. 2017, 19:49
je viens juste d'installé les plugin script et théme
J'ai pas les mêmes versions que toi
log kodi ::
beber@beber-Portable:~/.kodi/temp$ cat kodi.log
19:38:24 T:140685033396608 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:38:24 T:140685033396608 NOTICE: -----------------------------------------------------------------------
19:38:24 T:140685033396608 NOTICE: Starting Kodi (16.1 Git:c327c53). Platform: Linux x86 64-bit
19:38:24 T:140685033396608 NOTICE: Using Release Kodi x64 build
19:38:24 T:140685033396608 NOTICE: Kodi compiled Apr 25 2016 by GCC 5.3.1 for Linux x86 64-bit version 4.4.6 (263174)
19:38:24 T:140685033396608 NOTICE: Running on Ubuntu 16.04.1 LTS, kernel: Linux x86 64-bit version 4.4.0-62-generic
19:38:24 T:140685033396608 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
19:38:24 T:140685033396608 NOTICE: Host CPU: Intel(R) Core(TM) i7 CPU Q 840 @ 1.87GHz, 8 cores available
19:38:24 T:140685033396608 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
19:38:24 T:140685033396608 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
19:38:24 T:140685033396608 NOTICE: special://masterprofile/ is mapped to: /home/beber/.kodi/userdata
19:38:24 T:140685033396608 NOTICE: special://home/ is mapped to: /home/beber/.kodi
19:38:24 T:140685033396608 NOTICE: special://temp/ is mapped to: /home/beber/.kodi/temp
19:38:24 T:140685033396608 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
19:38:24 T:140685033396608 NOTICE: Local hostname: beber-Portable
19:38:24 T:140685033396608 NOTICE: Log File is located: /home/beber/.kodi/temp/kodi.log
19:38:24 T:140685033396608 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - La propriété « OnLowBattery » n'existe pas
19:38:24 T:140685033396608 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - La propriété « CanSuspend » n'existe pas
19:38:24 T:140685033396608 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - La propriété « CanHibernate » n'existe pas
19:38:24 T:140685033396608 NOTICE: load settings...
19:38:24 T:140685033396608 NOTICE: Found 1 Lists of Devices
19:38:24 T:140685033396608 NOTICE: Enumerated PULSE devices:
19:38:24 T:140685033396608 NOTICE: Device 1
19:38:24 T:140685033396608 NOTICE: m_deviceName : Default
19:38:24 T:140685033396608 NOTICE: m_displayName : Default
19:38:24 T:140685033396608 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
19:38:24 T:140685033396608 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:38:24 T:140685033396608 NOTICE: m_channels : FL,FR
19:38:24 T:140685033396608 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
19:38:24 T:140685033396608 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
19:38:24 T:140685033396608 NOTICE: Device 2
19:38:24 T:140685033396608 NOTICE: m_deviceName : alsa_output.pci-0000_01_00.1.hdmi-stereo
19:38:24 T:140685033396608 NOTICE: m_displayName : High Definition Audio Controller (Latitude E6510) Digital Stereo (HDMI)
19:38:24 T:140685033396608 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
19:38:24 T:140685033396608 NOTICE: Device 3
19:38:24 T:140685033396608 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
19:38:24 T:140685033396608 NOTICE: m_displayName : Audio interne Stéréo analogique
19:38:24 T:140685033396608 NOTICE: m_displayNameExtra: Haut-parleurs (PULSEAUDIO)
19:38:24 T:140685033396608 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:38:24 T:140685033396608 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:38:24 T:140685033396608 NOTICE: Default DVD Player: dvdplayer
19:38:24 T:140685033396608 NOTICE: Default Video Player: dvdplayer
19:38:24 T:140685033396608 NOTICE: Default Audio Player: paplayer
19:38:24 T:140685033396608 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:38:24 T:140685033396608 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
19:38:24 T:140685033396608 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:38:24 T:140685033396608 NOTICE: Loaded playercorefactory configuration
19:38:24 T:140685033396608 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:38:24 T:140685033396608 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:38:24 T:140684517889792 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:38:24 T:140685033396608 NOTICE: Running database version Addons20
19:38:24 T:140685033396608 NOTICE: ADDONS: Using repository repository.xbmc.org
19:38:24 T:140685033396608 NOTICE: Setup SDL
19:38:24 T:140685033396608 NOTICE: Checking resolution 16
19:38:24 T:140685033396608 NOTICE: Using visual 0x28
19:38:25 T:140685033396608 NOTICE: GL_VENDOR = NVIDIA Corporation
19:38:25 T:140685033396608 NOTICE: GL_RENDERER = NVS 3100M/PCIe/SSE2
19:38:25 T:140685033396608 NOTICE: GL_VERSION = 3.3.0 NVIDIA 340.101
19:38:25 T:140685033396608 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
19:38:25 T:140685033396608 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
19:38:25 T:140685033396608 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 524288
19:38:25 T:140685033396608 NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_gpu_program4_1 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
19:38:25 T:140685033396608 NOTICE: Running database version Addons20
19:38:25 T:140685033396608 NOTICE: Running database version ViewModes6
19:38:25 T:140685033396608 NOTICE: Running database version Textures13
19:38:25 T:140685033396608 NOTICE: Running database version MyMusic56
19:38:25 T:140685033396608 NOTICE: Running database version MyVideos99
19:38:25 T:140685033396608 NOTICE: Running database version TV29
19:38:25 T:140685033396608 NOTICE: Running database version Epg11
19:38:25 T:140685033396608 NOTICE: start dvd mediatype detection
19:38:25 T:140685033396608 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:38:25 T:140685033396608 NOTICE: ActiveAE DSP - starting
19:38:25 T:140685033396608 NOTICE: initialize done
19:38:25 T:140685033396608 NOTICE: Running the application...
19:38:25 T:140685033396608 NOTICE: starting zeroconf publishing
19:38:25 T:140685033396608 NOTICE: starting upnp client
19:38:25 T:140683373430528 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:38:25 T:140683373430528 NOTICE: UDP: Listening on port 9777
19:38:36 T:140685033396608 ERROR: GetDirectory - Error getting /home/beber/.kodi/media/Fonts/
19:38:36 T:140685033396608 ERROR: GetDirectory - Error getting special://home/media/Fonts/
19:38:39 T:140685033396608 ERROR: GetDirectory - Error getting /home/beber/.kodi/media/Fonts/
19:38:39 T:140685033396608 ERROR: GetDirectory - Error getting special://home/media/Fonts/
19:38:41 T:140685033396608 ERROR: GetDirectory - Error getting /home/beber/.kodi/media/Fonts/
19:38:41 T:140685033396608 ERROR: GetDirectory - Error getting special://home/media/Fonts/
19:38:44 T:140685033396608 ERROR: GetDirectory - Error getting /home/beber/.kodi/media/Fonts/
19:38:44 T:140685033396608 ERROR: GetDirectory - Error getting special://home/media/Fonts/
19:42:40 T:140684517889792 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:45:47 T:140683356645120 NOTICE: Skin Helper Service --> skin helper service version 1.0.100 started
19:45:47 T:140683356645120 NOTICE: Skin Helper Service --> WebService - start helper webservice on port 52307
19:46:48 T:140685033396608 WARNING: CSkinInfo: failed to load skin settings
19:46:59 T:140684517889792 WARNING: Previous line repeats 1 times.
19:46:59 T:140684517889792 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:50:39 T:140685033396608 NOTICE: Previous line repeats 1 times.
19:50:39 T:140685033396608 WARNING: CSkinInfo: failed to load skin settings
19:51:05 T:140684100851456 NOTICE: version 1.0.1 started
19:51:05 T:140684100851456 NOTICE: finished
19:51:30 T:140684100851456 NOTICE: version 1.0.1 started
19:51:30 T:140684100851456 NOTICE: finished
19:51:31 T:140684100851456 NOTICE: version 1.0.1 started
19:51:31 T:140684100851456 NOTICE: Previous line repeats 1 times.
19:51:31 T:140684100851456 NOTICE: finished
19:51:35 T:140684109244160 NOTICE: Previous line repeats 1 times.
19:51:35 T:140684109244160 NOTICE: version 1.0.1 started
19:51:35 T:140684109244160 NOTICE: finished
19:51:37 T:140684109244160 NOTICE: version 1.0.1 started
19:51:37 T:140684109244160 NOTICE: finished
19:51:38 T:140684109244160 NOTICE: version 1.0.1 started
19:51:38 T:140684109244160 NOTICE: finished
19:51:39 T:140684109244160 NOTICE: finished
19:51:41 T:140684109244160 NOTICE: version 1.0.1 started
19:51:41 T:140684109244160 NOTICE: finished
19:51:42 T:140684109244160 NOTICE: version 1.0.1 started
19:51:42 T:140684109244160 NOTICE: finished
19:51:46 T:140684109244160 NOTICE: version 1.0.1 started
19:51:46 T:140684109244160 NOTICE: finished
19:51:47 T:140684109244160 NOTICE: version 1.0.1 started
19:51:47 T:140684109244160 NOTICE: finished
19:51:48 T:140684509497088 NOTICE: version 1.0.1 started
19:51:48 T:140684509497088 NOTICE: finished
19:51:49 T:140684509497088 NOTICE: version 1.0.1 started
19:51:49 T:140684509497088 NOTICE: finished
19:52:17 T:140684517889792 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:52:31 T:140685033396608 NOTICE: WebServer: Started the webserver
19:52:32 T:140684092458752 NOTICE: version 1.0.1 started
19:52:32 T:140684092458752 NOTICE: finished
19:52:33 T:140684092458752 NOTICE: version 1.0.1 started
19:52:33 T:140684092458752 NOTICE: finished
19:52:33 T:140684084066048 NOTICE: version 1.0.1 started
19:52:33 T:140684084066048 NOTICE: finished
19:52:34 T:140684084066048 NOTICE: version 1.0.1 started
19:52:34 T:140684084066048 NOTICE: finished
19:52:56 T:140685033396608 NOTICE: ES: Stopping event server with confirmation
19:52:57 T:140683373430528 NOTICE: ES: UDP Event server stopped
19:52:57 T:140683373430528 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:52:57 T:140683373430528 NOTICE: UDP: Listening on port 9777
19:55:00 T:140684517889792 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
19:55:16 T:140685033396608 ERROR: Control 9501 in window 11201 has been asked to focus, but it can't
19:55:16 T:140684121831168 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.TypeError'>
Error Contents: string indices must be integers, not str
File "/home/beber/.kodi/addons/script.jeedomgui/default.py", line 36, in <module>
Main()
File "/home/beber/.kodi/addons/script.jeedomgui/default.py", line 29, in __init__
StartActions( self ,self.params )
File "/home/beber/.kodi/addons/script.jeedomgui/resources/lib/process.py", line 29, in StartActions
InitLights()
File "/home/beber/.kodi/addons/script.jeedomgui/resources/lib/Light.py", line 64, in InitLights
LoadShortcuts(jeedomconfig["shortcuts"])
TypeError: string indices must be integers, not str
-->End of Python script error report<--
Jeedom Version Dev sur Vm Debian
configuration, voir profil
lijah
Message par lijah » 25 janv. 2017, 20:02
tocks a écrit :1) le mot de passe est en clair
bonne remarque, je vais modifier ca.
2) c'est obligé d'utiliser ton skin ? Tu va prévoir de pouvoir utiliser d'autre skin par la suite ?
oui il n'y a que ce skin de dispo. Les skin kodi ce ne sont pas de simple css ,C'est assez lourd a faire et a modifier. Et c'est tres dépendant de la facon dont le skin a été fait. Donc je n'adapterais probablement un autre skin tout seul. Mais je suis ouvert a la collaboration.
3) dans la doc tu dis
http:/xxx.xxx.xxx.xxx//plugins/kodiasgui/core/api/kodiasgui.api.php?func=push
mais c'est :
http:/xxx.xxx.xxx.xxx/plugins/kodiasgui/core/api/kodiasgui.api.php?func=push
ok
pour : Si vous utilisez deja cette adresse de Push pour autre chose, ce plug-in permettra bientot d’enchainer le push sur une autre adresse.
J'ai absolument rien compris, peux tu nous en dire plus
On ne peu définir qu'une seule adresse de push dans jeedom , donc si elle est deja utilisée ... on est coincé
Je vais donc faire en sorte que mon plug-in puisse enchainer sur une autre adresse de push apres avoir été appelé.
4) je ne trouve pas cet écran dans jeedom de configuration des commandes.
C'est dans la configuration générale de jeedom pas du plug-in. ( l'engrenage dans le coin supérieur droit)
En tous cas bravo, c'est rare de voir quelqu'un qui nous sort son premier plugin avec de la doc et tou et tou. BRAVO, même si je n'ai pas encore tous configuré et testé. Je ne doute pas que cela doit marcher
Faut pas s'emballer ya plein plein de chose qui ne marche pas encore. J'ai publié cette première Beta pour ceux qui veulent suivre le dev et orienter les évolutions.
lunarok
Message par lunarok » 25 janv. 2017, 20:19
Encore des erreurs :
Warning: array_key_exists() expects parameter 2 to be array, string given in /usr/share/nginx/www/jeedom/plugins/kodiasgui/core/ajax/kodiasgui.ajax.php on line 45
Warning: array_key_exists() expects parameter 2 to be array, string given in /usr/share/nginx/www/jeedom/plugins/kodiasgui/core/ajax/kodiasgui.ajax.php on line 49
Apparemment lors de la réception depuis le Kodi (je les vois arriver depuis que j'ai configuré le plugin script)
Par contre toujours rien dans l'écran et je me demande, vu qu'on peut saisir qu'une IP si mon jeedom est bien en écoute sur un vhost avec IP, je vais vérifier et les logs aussi
Mon Blog | Xiaomi Home
Bostoc
Message par Bostoc » 26 janv. 2017, 09:32
Bonne idée tout ca.
Beau travail !
NUC Debian / Zwave / RfxCom / EnOcean
lijah
Message par lijah » 26 janv. 2017, 10:22
tocks a écrit :je viens juste d'installé les plugin script et théme
Visiblement ca coince quand ton Jeedom s'appel lui meme. Dans l'adresse du Push tu as bien mis l'ip que tu utilise pour l'interface web de Jeedom ?
Au passage , si quelqu'un connaît un autre moyen pour qu'un plug-in soit alerté de changements ? Je suis preneur.
olivierdomo
Message par olivierdomo » 26 janv. 2017, 11:09
@lijah : je t'ai fais un PR github concernant la documentation et modification de mise en page de la page configuration générale de ton plugin :)
Envoyé de mon iPad en utilisant Tapatalk
Configuration et profil : memberlist.php?mode=viewprofile&u=241 => MAJ des équipements en cours
beber53
Message par beber53 » 26 janv. 2017, 14:17
@olivierdomo, as tu réussit à utiliser le plugin ?
lijah
Message par lijah » 26 janv. 2017, 14:26
lunarok a écrit :Apparemment lors de la réception depuis le Kodi (je les vois arriver depuis que j'ai configuré le plugin script)
Je n'avais pas pensé à ce cas la. Il faudra que je remplace le parametre IP par un textbox IP/Hotsname
olivierdomo
Message par olivierdomo » 26 janv. 2017, 23:49
tocks a écrit :@olivierdomo, as tu réussit à utiliser le plugin ?
Je n'utilise pas (encore) le plugin, j'ai juste fait une relecture et des corrections syntaxiques et orthographiques de la documentation et remis légèrement en page la page de configuration générale du plugin (champs qui debordaient des cadres et quelques autres modifications) qui ont été fusionné sur Github par l'auteur @lijah
Envoyé de mon SM-G930F en utilisant Tapatalk
didier.gauche
Message par didier.gauche » 28 janv. 2017, 11:06
bonjour merci pour cette idée ,mais je ne vois pas le plugin.
didier.gauche
Message par didier.gauche » 28 janv. 2017, 14:50
Erreur sur kodi :
Erreur jeedom ui script
mbuffat69
Message par mbuffat69 » 28 janv. 2017, 18:18
je viens d'installer le plugin et les extensions sur kodi (gui et script)
La configuration semble fonctionner puisque je recupère bien l'IP de kodi
dans le configuration Jeedom.
Par contre je n'ai aucun affichage d'équipements sur Kodi et des erreurs dans les logs kodi
17:39:11  48.722157 T:1679164336   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.KeyError'>
                                            Error Contents: ('image',)
                                              File "/home/pi/.kodi/addons/script.jeedomgui/default.py", line 36, in <module>
                                                Main()
                                              File "/home/pi/.kodi/addons/script.jeedomgui/default.py", line 29, in __init__
                                              File "/home/pi/.kodi/addons/script.jeedomgui/resources/lib/process.py", line 20, in StartActions
                                                LoadHome()
                                              File "/home/pi/.kodi/addons/script.jeedomgui/resources/lib/Home.py", line 53, in LoadHome
                                                LoadPlan(jeedomconfig["image"])
                                            KeyError: ('image',)
17:48:01 577.934082 T:1944227840   ERROR: Control 9501 in window 11202 has been asked to focus, but it can't
17:48:42 619.646240 T:1944227840   ERROR: Previous line repeats 7 times.
17:48:42 619.646362 T:1944227840   ERROR: Keymapping error: no such action '' defined
17:49:02 639.403687 T:1944227840   ERROR: Previous line repeats 1 times.
17:49:02 639.403809 T:1944227840   ERROR: Control 9501 in window 11205 has been asked to focus, but it can't
17:56:31 1088.663208 T:1944227840   ERROR: Previous line repeats 3 times.
17:56:31 1088.663330 T:1944227840   ERROR: Control 9501 in window 11201 has been asked to focus, but it can't
17:58:16 1193.418945 T:1944227840   ERROR: Previous line repeats 7 times.
17:58:16 1193.419067 T:1944227840   ERROR: Keymapping error: no such action '' defined
Sous jeedom j'ai aussi les logs suivants
dans kodiasgui:
[2017-01-28 18:03:18][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php  plugin_id=kodiasgui function=remove callInstallFunction=1
[2017-01-28 18:03:24][INFO] : Début d'activation du plugin
[2017-01-28 18:03:25][INFO] : Info sur le démon : Array (     [launchable_message] =>      [launchable] => nok     [state] => nok     [log] => nok     [auto] => 0 )
[2017-01-28 18:03:25][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php  plugin_id=kodiasgui function=install callInstallFunction=1
et dans http.err
[Sat Jan 28 17:57:53.486329 2017] [:error] [pid 1925] [client 192.168.0.53:35350] PHP Fatal error:  Call to a member function getDisplay() on null in /var/www/html/plugins/kodiasgui/core/ajax/kodiasgui.ajax.php on line 78, referer: http://jeedomgaule/index.php?v=d&m=kodiasgui&p=kodiasgui
[Sat Jan 28 17:57:53.487782 2017] [:error] [pid 31424] [client 192.168.0.53:35356] PHP Fatal error:  Call to a member function getDisplay() on null in /var/www/html/plugins/kodiasgui/core/ajax/kodiasgui.ajax.php on line 78, referer: http://jeedomgaule/index.php?v=d&m=kodiasgui&p=kodiasgui
[Sat Jan 28 17:57:53.492795 2017] [:error] [pid 1924] [client 192.168.0.53:35354] PHP Fatal error:  Call to a member function getDisplay() on null in /var/www/html/plugins/kodiasgui/core/ajax/kodiasgui.ajax.php on line 78, referer: http://jeedomgaule/index.php?v=d&m=kodiasgui&p=kodiasgui
De plus dans la page de configuration du plugin faut il remplir des choses ?
Dans Acceuil, Infos, .. j'ai des listes d'équipements avec des colonnes blanches à droite vides !
Aurais je loupé une étape de configuration ?
Sinon bonne idée pour ce plugin et j'espère que j'arriverai a le faire marcher !
Système DIY 2 PI3 avec SSD (voir mon profil pour le détail)
slayer91
Message par slayer91 » 31 janv. 2017, 17:24
Super ton idée. Utilisant kodi sur mes deux TV c'est vraiment interressant.
Par contre je voulais tester je ne trouve pas ton plugin sur le market. Est-il dispo que pour les bêta-testeurs ?
Si non comment peux-ton faire pour l'installer un direct depuis Github sur Jeedom ?
olivierdomo
Message par olivierdomo » 31 janv. 2017, 18:01
slayer91 a écrit :Bonjour,
Hello
Pour charger un zip, c'est très simple,
1)
si tu n'a pas encore activé l'upload par fichier (l'option n’apparaît pas dans le dropdown type de source), il faut au préalable dans Configuration/Mise à jour et fichiers/Onglet Fichier, cocher "activer fichier", puis sauvegarder...
2)
depuis le menu Plugins/Gestion des plugins, sur la gauche tu as un "+ ajouter depuis une autre source". il faut choisir ça, puis dans le popup 'type de source" choisir fichier. Ensuite dans le nom de plugin il faut mettre "kodiasgui")( à vérifier ici*) puis uploader le zip, (toujours zipper) que tu auras préalablement télécharger sur ton PC depuis le dépôt Github kodiasgui. C'est tout.
id-plugin est à remplacer par l' id du plugin que tu trouveras dans le répertoire "plugin_info" puis->info.xml
Envoyé via Tapatalk Mobile
slayer91
Message par slayer91 » 31 janv. 2017, 18:13
Merci Olivierdomo pour ton retour.
Effectivement je n'avais pas l'envoie par fichier activé.
Par contre pourquoi il n'est pas visible sur le Market ?
lijah
Message par lijah » 31 janv. 2017, 18:33
Oui tu as loupé une étape de configuration. Pour chaque équipement il faut définir un Alias ( nom affiché que tu choisi librement ) et spécifier le type d'équipement dont il s'agit. La liste des types supportés est dans la doc de configuration.
lijah
Message par lijah » 31 janv. 2017, 18:47
olivierdomo a écrit :Bonjour,
Merci du coup de main Olivier,
Les corrections sont incluses dans la Beta 0.9.1
La Beta 0.9.1 est dispo sous GitHub.
https://github.com/rmesnard/kodiasgui/releases
https://github.com/rmesnard/skin.jeedomgui/releases
https://github.com/rmesnard/script.jeedomgui
- Les fonctions Eclairages sont toutes fonctionelles : switch, réglage luminosité , couleurs.
- Le mode plan fonctionne sur la page Eclairages.
- Il y a de nouveaux parametres pour définir un hostname coté Kodi, et une IP fixe coté Jeedom.
+ Divers corrections sur l'interface et la skin.
Pour la mise a jours de la Beta je vous conseil d'utiliser le plug-in Jeedom "Outil de Developpement" pour mettre à jours directement les fichiers dans le repertoire du plug-in.
slayer91
Message par slayer91 » 31 janv. 2017, 18:58
Bon je viens d'installer le plugin sur jeedom.
Cependant je n'arrive pas à installer le skin et le script sur kodi. Quand j'essaye d'installer sur kodi j'ai l'erreur "kodi dependencies not met,..."
J'ai bien le repositories kodi officiel d'activé.
Je ne comprend pas.
Avez-vous des idées ?
olivierdomo
Message par olivierdomo » 31 janv. 2017, 19:20
De rien :) il est absent car il est peut être en bêta test (donc non visible par les utilisateurs finaux (même si les bêta testeurs sont quand même des utilisateurs finaux en définitive) ou problème d'upload du plugin depuis github vers le market (supposition)
beber53
Message par beber53 » 01 févr. 2017, 11:14
Merci lijah , pour cette mise à jours.
Mais je ne voie pas de mise a jours sur ton plugin sur le market . As tu bien poussé la mise à jours dessus ?
Revenir vers « [Catégorie] Multimédia »
