Page 9 sur 9
Re: Tuto - netinstall sur Mini + (Solidrun humingboard) via script officiel
Publié : 06 déc. 2017, 22:13
par Fab38
J'ai réussi à passer l’étape du swap. Problème formatage de la carte SD.
Maintenant, je bloque dans l'installation au step 2.
Avez vous une idée ??
Welcome to Linux on i.MX6. This System comes preinstalled with "imx6-config" , a user-friendly tool to manipulate system settings.
debian@linux:~$ free -m
total used free shared buffers cached
Mem: 494 490 3 8 13 293
-/+ buffers/cache: 183 311
Swap: 0 0 0
Mem: 494 489 4 8 13 293
-/+ buffers/cache: 182 311
Swap: 511 0 511
debian@linux:~$ wget https://raw.githubusercontent.com/jeedo ... ble/instal l/install.sh
--2017-12-06 21:05:34-- https://raw.githubusercontent.com/jeedom/core/stable/in stall/install.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.60.13 3
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.60.1 33|:443... connected.
Length: 15335 (15K) [text/plain]
Saving to: ‘install.sh’
install.sh 100%[=====================>] 14.98K --.-KB/s in 0.04s
2017-12-06 21:05:35 (360 KB/s) - ‘install.sh’ saved [15335/15335]
debian@linux:~$ chmod +x install.sh
debian@linux:~$ sudo ./install.sh
[sudo] password for debian:
Welcome to jeedom installer
Jeedom install version : stable
Webserver home folder : /var/www/html
Start of all install step
Start step_1_upgrade
Get:1 http://security.debian.org jessie/updates InRelease [63.1 kB]
Get:2 https://repo.solid-build.xyz ./ InRelease [354 B]
Ign https://repo.solid-build.xyz ./ InRelease
Get:3 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Ign http://httpredir.debian.org jessie InRelease
Get:4 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Get:5 http://security.debian.org jessie/updates/main Sources [200 kB]
Get:6 https://repo.solid-build.xyz ./ Release [982 B]
Get:7 https://repo.solid-build.xyz ./ Sources [24.7 kB]
Hit http://httpredir.debian.org jessie Release.gpg
Get:8 https://repo.solid-build.xyz ./ Packages [51.5 kB]
Get:9 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:10 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:11 http://security.debian.org jessie/updates/main armhf Packages [460 kB]
Get:12 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:13 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:14 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:15 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:16 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:17 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:18 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Ign https://repo.solid-build.xyz ./ Translation-en_US
Get:19 https://repo.solid-build.xyz ./ Translation-en [351 B]
Hit http://httpredir.debian.org jessie-updates/main Sources
Get:20 http://security.debian.org jessie/updates/main Translation-en [230 kB]
Get:21 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [9,376 B]
Get:22 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3,688 B]
Hit http://httpredir.debian.org jessie/main Sources
Hit http://httpredir.debian.org jessie/main armhf Packages
Hit http://httpredir.debian.org jessie/main Translation-en
Ign http://security.debian.org jessie/updates/main Translation-en
Err http://httpredir.debian.org jessie/main armhf Packages
Ign http://httpredir.debian.org jessie/main Translation-en
404 Not Found [IP: 151.101.60.204 80]
Fetched 1,189 kB in 12s (93.9 kB/s)
W: Failed to fetch copy:/var/lib/apt/lists/partial/httpredir.debian.org_debian_d ists_jessie_main_source_Sources.xz rename failed, Read-only file system (/var/l ib/apt/lists/partial/httpredir.debian.org_debian_dists_jessie_main_source_Source s -> /var/lib/apt/lists/httpredir.debian.org_debian_dists_jessie_main_source_Sou rces).
W: Failed to fetch http://httpredir.debian.org/debian/dist ... n/binary-a rmhf/Packages 404 Not Found [IP: 151.101.60.204 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
W: Not using locking for read only lock file /var/lib/dpkg/lock
E: Unable to write to /var/cache/apt/
E: The package lists or status file could not be parsed or opened.
step_1_upgrade success
Start step_2_mainpackage
Could not install ntp ca-certificates unzip curl sudo cron - abort
debian@linux:~$
merci de votre aide.
Publié : 16 déc. 2017, 11:57
par bronche
Normal... ton swap est déjà en.place...
C'est mon image ?
Phil
Publié : 25 déc. 2017, 17:16
par Fab38
Bonjour Bronche,
Merci avant tout pour ta réponse.
Oui, il s'agissait de ton image.
Je pense que ma carte SD devait être corrompue ?
Depuis, j'ai pris la Smart et tout est rentré dans l'ordre.
Merci encore
Publié : 15 janv. 2018, 22:32
par PHDB
bronche a écrit :
02 déc. 2017, 08:56
Un autre dépôt.
Regarde ça :
https://doc.ubuntu-fr.org/depots
Il faut que je me penche la dessus, mais en ce moment un peu noyé...
Desolé, c'est au delà de mes compétences. Je risque de faire plus de dégats que d'améliorations je pense. Ceci étant, si jamais tu as un peu de temps pour comprendre ce qui déconne et faire en sorte que le plugin Dash button fonctionne, je t'en suis reconnaissant. Bien sur je comprends que ca ne soit pas ta priorité!
Publié : 10 févr. 2018, 15:16
par StephTheMad
Bonjour Bronche. Merci pour ce que tu fais (videos et tutos). Cela m'aide beaucoup. J'ai exactement le même problème que PHDB. J'ai une mini + en V2.4.6. J'ai suivi ce que tu lui as dit. J'ai gravé ton image en V3.0.11 puis restauré l'image de ma v2.4.6. Cela fonctionne sauf que déjà là j'ai 4 erreurs de plugin et pas des moindres (RFXCOM / Zwabe / Broadlink et 4ieme je ne sais plus). J'ai tout de même testé de mettre à jour en V3.1.7 mais là ça refait le pb en mettant à jour directement de la 2.4.6 vers 3.1.7. Pb de sql. J'aimerais vraiment récupérer ma config du moins les capteurs RFXcom et Zwave pour une version 3.1.7. Aurais-tu une idée de ce que je peux faire.
En attendant je repasse en V3.0.11 avec ma resto 2.4.6 et essayer de réparer les différentes erreurs. Merci pour ton aide
Publié : 10 févr. 2018, 18:28
par StephTheMad
bon je me réponds à moi-même. J'avais oublié un paramètre important que tu suggères : la patience. Lors de la mise à jour en v3.1.7, je n'avais pas été au bout. un peu de temps au bout de 30 min et tout était ok. Encore merci
Publié : 30 juin 2018, 22:26
par PHDB
je me suis repenché sur mon probleme de Dash button (demon NOK) que j'aimerais bien refaire fonctionner.
viewtopic.php?p=631585#p631535
Sur les conseils du post j'ai fait
~$ sudo apt-get install libpcap-dev
Reading package lists... Done
Building dependency tree
libpcap-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 150 not upgraded.
Du coup vu que j'ai 150 paquets obsoletes, on m'a conseille sudo apt-get update && apt-get upgrade
Ce qui me donne
debian@linux:~$ sudo apt-get update && apt-get upgrade
Get:1 http://security.debian.org jessie/updates InRelease [44.9 kB]
Ign http://http.us.debian.org jessie InRelease
Hit https://deb.nodesource.com jessie InRelease
Get:2 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Hit http://http.us.debian.org jessie Release.gpg
Get:3 http://security.debian.org jessie/updates/main Sources [226 kB]
Get:4 https://repo.solid-build.xyz ./ InRelease [354 B]
Hit https://repo.solid-build.xyz ./ Release.gpg
Hit https://deb.nodesource.com jessie/main Sources
Get:5 http://security.debian.org jessie/updates/main armhf Packages [449 kB]
Hit http://security.debian.org jessie/updates/main Translation-en
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:6 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:7 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:8 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:9 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:10 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:14 https://deb.nodesource.com jessie/main Translation-en_US [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en_US
Get:15 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:16 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Hit http://http.us.debian.org jessie/non-free armhf Packages
Get:17 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3,688 B]
Hit http://http.us.debian.org jessie/non-free Translation-en
Hit https://repo.solid-build.xyz ./ Sources
Hit https://repo.solid-build.xyz ./ Packages
Get:20 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:21 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:22 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:23 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:24 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:25 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:26 https://repo.solid-build.xyz ./ Translation-en_US [354 B]
Get:27 https://repo.solid-build.xyz ./ Translation-en [351 B]
Fetched 881 kB in 22s (40.0 kB/s)
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you root?
Une idee pour resoudre ce souci de mise a jour? Ou mieux mon souci de Dash?
PS: comme dans mes precedents tests plus hauts dans ce post "su -" me renvoie "su: Authentication failure"
debian@linux:~$ su -
Password:
debian@linux:~$ lsb_release -idrc
Distributor ID: Debian
Description:    Debian GNU/Linux 8.9 (jessie)
Release:        8.9
Codename:       jessie
Publié : 02 juil. 2018, 19:03
par bronche
Bonsoir.
Houla.... :D
Ça sera mieux comme ça ;)
sudo apt-get update
PUIS
sudo apt-get upgrade
et si vraiment tu tiens à tout mettre sur une ligne
sudo apt-get update && sudo apt-get upgrade
Dans ta façon de faire, tu n'es pas root pour la deuxième commande.
Enfin, la commande su n'existe pas sur cette distribution. Par ailleurs elle ne veut pas dire super utilisateur, mais switch user.
Phil
Publié : 12 juil. 2018, 12:14
par PHDB
Super, merci. Ca marche mieux comme ca :)
Publié : 06 nov. 2018, 14:39
par Antoinekl1
je veux résintaller ma mini+ pour faire un backup de ma smart
j'ai pas lu les 9 pages du topic, mais je suppose que vue le nom de l'image :Mini plus Strecht jeedom 3.1.7 Strecht recommandée.rar
les informations de la 1er pages ne sont plus bonne et que la version stecht est bonne maintenant ?
Publié : 06 nov. 2018, 15:37
par bronche
Bonjour Antoine,
Non c'est bon avec la strecht.
Tu peux y aller.
J'ai mis à jour le premier post.
Attention le temps de mise à jour des dépendances peut être très très long.
Phil
Publié : 06 nov. 2018, 17:15
par Antoinekl1
bronche a écrit :
06 nov. 2018, 15:37
Bonjour Antoine,
Tu peux y aller.
Phil
Ok parfait, merci pour le taf
faut que je trouve la procédure et je me lance :-)
Publié : 26 nov. 2018, 11:31
par maccaire
Je galere pour installer les dependances du plugin snips je lance la commande:sudo apt-get update && sudo apt-get upgrade et je vois defiler une erreur: Err https://repo.solid-build.xyz ./ Release
Voici mon fichier sources.list
deb http://httpredir.debian.org/debian jessie main
deb-src http://httpredir.debian.org/debian jessie main
deb http://httpredir.debian.org/debian jessie-updates main
deb-src http://httpredir.debian.org/debian jessie-updates main
deb http://security.debian.org/ jessie/updates main
deb-src http://security.debian.org/ jessie/updates main
deb http://http.us.debian.org/debian/ jessie non-free
Peut et il incomplet.
