Pour résumer :
500 internal server error
Pour toute question concernant le plugin caméra
yohann74
Message par yohann74 » 05 déc. 2017, 22:06
J ai un soucis sur le Jeedom de mon père qui est sur une mini. Lorsque je veux aller sur la configuration du plugin camera il me met 500 internal server error
oui j ai pas spécifié les caméras ne fonctionnent plus.
les logs nginx error sont :
2017/12/05 20:32:55 [error] 444#0: *53 FastCGI sent in stderr: "PHP message: PHP Fatal error: Call to undefined function curl_init() in /usr/share/nginx/www/jeedom/plugins/camera/core/class/camera.class.php on line 655" while reading response header from upstream, client: 10.9.0.1, server: , request: "GET /plugins/camera/core/php/snapshot.php?id=125&apikey=msYMsqD2ykG0M2nYBk**************=1512505969464&thumbnail=1&width=330 HTTP/1.0", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "*******.dns2.jeedom.com", referrer: "https://*******.dns2.jeedom.com/index.php?v=d&p=dashboard"
2017/12/05 20:32:55 [error] 444#0: *55 FastCGI sent in stderr: "PHP message: PHP Fatal error: Call to undefined function curl_init() in /usr/share/nginx/www/jeedom/plugins/camera/core/class/camera.class.php on line 655" while reading response header from upstream, client: 10.9.0.1, server: , request: "GET /plugins/camera/core/php/snapshot.php?id=4&apikey=b1F4ldgsOhdD5cGJ6*************QMDaxnRjWiKcA7&t=1512505969496&thumbnail=1&width=680 HTTP/1.0", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "*******.dns2.jeedom.com", referrer: "https://*******.dns2.jeedom.com/index.php?v=d&p=dashboard"
2017/12/05 20:32:55 [error] 444#0: *57 FastCGI sent in stderr: "PHP message: PHP Fatal error: Call to undefined function curl_init() in /usr/share/nginx/www/jeedom/plugins/camera/core/class/camera.class.php on line 655" while reading response header from upstream, client: 10.9.0.1, server: , request: "GET /plugins/camera/core/php/snapshot.php?id=5&apikey=iZ5u1OPeRmTJQI***********RNvDHbIMExP41wRqDRmCYq&t=1512505969608&thumbnail=1&width=640 HTTP/1.0", upstream: "fastcgi://unix:/var/run/php5-fpm.sock:", host: "*******.dns2.jeedom.com", referrer: "https://*******.dns2.jeedom.com/index.php?v=d&p=dashboard"
2017/12/05 20:33:00 [error] 444#0: *61 FastCGI sent in stderr: "PHP message: PHP Fatal error: Call to undefined function curl_init() in /usr/share/nginx/www/jeedom/core/class/network.class.php on line 211" while reading response header from upstre
J ai deja essayé le reboot mais pas mieux
une idée?? merci d avance
yohann74
Re: 500 internal server error
Message par yohann74 » 09 déc. 2017, 10:14
Vous auriez une idée car je suis bloqué... je ne peux pas supprimer le plugin ni faire quoi que ce soit...
loic
Administrateur
Message par loic » 09 déc. 2017, 10:25
En ssh essayer de faire sudo apt-get install php5-curl
yohann74
Message par yohann74 » 09 déc. 2017, 13:26
Merci beaucoup de ton intérêt Loïc malheureusement je ne suis pas sur place j y ai accès que par dns.
Si je n ai pas d autre solution j attendrai d y retourner et je testerai ce que tu m'as dit.
yohann74
Message par yohann74 » 29 janv. 2018, 13:23
Bonjour Loic,
Ca y est j ai acccès au ssh du jeedom mini de mes parents. Le problème était que je n avais plus accès au plugin caméra.
Depuis je n ai plus accès au dns ni au panneau de configuration non plus, mais cela vient peut être du même problème.
Donc tu m avais demandé de taper en ssh : apt-get install php5-curl
Voila la réponse
root@jeedom:/home/jeedom# apt-get install php5-curl
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
root@jeedom:/home/jeedom# Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
Options: command not found
J ai bien essayé plusieurs manip pour continuer mais je galère ne SSH et avec la commande dpkg ...
Merci d avance
loic
Administrateur
Message par loic » 29 janv. 2018, 14:30
Il faut faire :
Comme le dit le retour de la commande.
yohann74
Message par yohann74 » 29 janv. 2018, 17:42
Effectivement j ai pas brillé la dessus.
Bon je crois que j ai fait une boulette car je n ai plus accès a jeedom du tout ni en local ni en SSh
en fait a la fin de la manip j ai refait un apt-get install php5-curl et un reboot mais ca ne marchait toujours pas donc j ai continué comme tu peux le voir sur ce qui suis j ai fait ce que j ai mis en gras et depuis plus d accès ...
Cest grave a ton avis ??
Reading package lists... Done
Building dependency tree
Reading state information... Done
php5-curl is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
php5-curl : Depends: php5-common (= 5.6.30+dfsg-0+deb8u1) but 5.6.17+dfsg-0+deb 8u1 is to be installed
php5-fpm : Depends: php5-common (= 5.6.30+dfsg-0+deb8u1) but 5.6.17+dfsg-0+deb8 u1 is to be installed
php5-ldap : Depends: php5-common (= 5.6.30+dfsg-0+deb8u1) but 5.6.17+dfsg-0+deb 8u1 is to be installed
php5-mysql : Depends: php5-common (= 5.6.30+dfsg-0+deb8u1) but 5.6.17+dfsg-0+de b8u1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a s olution).
root@jeedom:/home/jeedom# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
php5-cli php5-common php5-fpm php5-readline
Suggested packages:
php5-user-cache
The following packages will be upgraded:
4 upgraded, 0 newly installed, 0 to remove and 197 not upgraded.
4 not fully installed or removed.
Need to get 0 B/4,685 kB of archives.
After this operation, 117 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 53225 files and directories currently installed.)
Preparing to unpack .../php5-readline_5.6.30+dfsg-0+deb8u1_armhf.deb ...
Unpacking php5-readline (5.6.30+dfsg-0+deb8u1) over (5.6.17+dfsg-0+deb8u1) ...
Preparing to unpack .../php5-cli_5.6.30+dfsg-0+deb8u1_armhf.deb ...
Unpacking php5-cli (5.6.30+dfsg-0+deb8u1) over (5.6.17+dfsg-0+deb8u1) ...
Preparing to unpack .../php5-fpm_5.6.30+dfsg-0+deb8u1_armhf.deb ...
Unpacking php5-fpm (5.6.30+dfsg-0+deb8u1) over (5.6.17+dfsg-0+deb8u1) ...
Preparing to unpack .../php5-common_5.6.30+dfsg-0+deb8u1_armhf.deb ...
Unpacking php5-common (5.6.30+dfsg-0+deb8u1) over (5.6.17+dfsg-0+deb8u1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u3) ...
Setting up php5-common (5.6.30+dfsg-0+deb8u1) ...
Setting up php5-cli (5.6.30+dfsg-0+deb8u1) ...
Setting up php5-readline (5.6.30+dfsg-0+deb8u1) ...
Setting up php5-fpm (5.6.30+dfsg-0+deb8u1) ...
Installing new version of config file /etc/init.d/php5-fpm ...
Setting up php5-curl (5.6.30+dfsg-0+deb8u1) ...
Setting up php5-ldap (5.6.30+dfsg-0+deb8u1) ...
Setting up php5-mysql (5.6.30+dfsg-0+deb8u1) ...
Processing triggers for php5-fpm (5.6.30+dfsg-0+deb8u1) ...
root@jeedom:/home/jeedom# reboot
Revenir vers « [Plugin officiel] Caméra »
