Plugin OpenZwave
Modérateur : nechry
tmartinez
Modérateur
Re: Plugin OpenZwave
Message par tmartinez » 28 mai 2015, 22:51
Salut, peux-tu nous dire ce que tu as dans les logs du plugin et de openzwave (console) ?
Qu'est ce que tu as dans l'interface avancée ?
Jeedom sous Proxmox
43 Modules Z-Wave / 1x RfxCom / 20 devices connectés
Mon matériel
alientouch
Message par alientouch » 28 mai 2015, 22:54
je viens de voir cela dans les notifications du plugin zwave :
Echec de la requete http : http://:/ZAutomation/api/v1/notifications?pagination=true&limit=100&since=0 Curl error : Could not resolve host:
sinon dans, openzwave :
Openzwave is installed.
28-05-2015 22:00:49 | info | ******** The ZWave network is being started ********
28-05-2015 22:00:49 | info | OpenZwave Library Version 1.3.0
28-05-2015 22:00:49 | info | Python-OpenZwave Wrapper Version 0.2.6
28-05-2015 22:00:49 | info | Waiting for network to become ready
28-05-2015 22:00:49 | info | Openzwave network are started with homeId 0184c759.
28-05-2015 22:00:49 | info | Controller state: Normal. No command in progress.
28-05-2015 22:00:49 | debug | Controller is busy: False
28-05-2015 22:00:49 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [1] name: [] model: [].
28-05-2015 22:00:49 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [9] name: [] model: [].
28-05-2015 22:00:49 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [10] name: [] model: [].
28-05-2015 22:00:49 | debug | The essential queries on a node have been completed. home_id: [0x0184c759] id: [1] name: [] model: [Z-Stick S2]
28-05-2015 22:00:49 | debug | All the initialisation queries on a node have been completed. home_id: [0x0184c759] id: [1] name: [] model: [Z-Stick S2]
28-05-2015 22:00:49 | info | write configuration xml file
28-05-2015 22:00:50 | info | Openzwave network is awake : 3 nodes were found (2 are sleeping). All listening nodes are queried, but some sleeping nodes may be missing.
28-05-2015 22:00:50 | info | Controller is : home_id: [0x0184c759] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78]
28-05-2015 22:00:50 | info | write configuration xml file
28-05-2015 22:01:49 | error | 404: Not Found http://127.0.0.1:8083/ZWaveAPI/Run/devi ... lChange(1)
28-05-2015 22:01:54 | error | 404: Not Found http://127.0.0.1:8083/ZWaveAPI/Run/devi ... lChange(0)
28-05-2015 22:02:25 | info | write configuration xml file
28-05-2015 22:03:23 | info | AddNodeToNetwork Started
Exception IndexError: 'list index out of range' in 'libopenzwave.notif_callback' ignored
28-05-2015 22:03:23 | info | Controller state: Waiting. Controller is waiting for a user action.
28-05-2015 22:03:23 | debug | Controller is busy: True
28-05-2015 22:03:53 | info | Cancels any in-progress command running on a controller.
28-05-2015 22:03:53 | info | Controller state: Completed. The command has completed successfully.
28-05-2015 22:03:53 | debug | Controller is busy: False
28-05-2015 22:06:11 | info | AddNodeToNetwork Started
28-05-2015 22:06:12 | info | Controller state: Starting. The command is starting.
28-05-2015 22:06:12 | debug | Controller is busy: False
28-05-2015 22:07:58 | debug | TestNetwork node 0
28-05-2015 22:07:58 | warning | This network does not contain any node with the id 0
28-05-2015 22:08:02 | info | HealNetwork
28-05-2015 22:16:48 | info | Resets a controller and erases its network configuration settings
SQLite version: 3.8.7.1
28-05-2015 22:20:59 | info | ******** The ZWave network is being started ********
28-05-2015 22:20:59 | info | OpenZwave Library Version 1.3.0
28-05-2015 22:20:59 | info | Python-OpenZwave Wrapper Version 0.2.6
28-05-2015 22:20:59 | info | Waiting for network to become ready
28-05-2015 22:20:59 | info | Openzwave network are started with homeId 0184c759.
28-05-2015 22:20:59 | info | Controller state: Normal. No command in progress.
28-05-2015 22:20:59 | debug | Controller is busy: False
28-05-2015 22:20:59 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [1] name: [] model: [Z-Stick S2].
28-05-2015 22:20:59 | debug | The essential queries on a node have been completed. home_id: [0x0184c759] id: [1] name: [] model: [Z-Stick S2]
28-05-2015 22:20:59 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [9] name: [] model: [].
28-05-2015 22:20:59 | info | A new node has been added to OpenZWave list. home_id: [0x0184c759] id: [10] name: [] model: [].
28-05-2015 22:21:00 | debug | All the initialisation queries on a node have been completed. home_id: [0x0184c759] id: [1] name: [] model: [Z-Stick S2]
28-05-2015 22:21:00 | info | write configuration xml file
28-05-2015 22:21:01 | info | Openzwave network is awake : 3 nodes were found (2 are sleeping). All listening nodes are queried, but some sleeping nodes may be missing.
28-05-2015 22:21:01 | info | Controller is : home_id: [0x0184c759] id: [1] name: [] product: [Z-Stick S2] capabilities: set(['primaryController', 'staticUpdateController']) library: [Static Controller version Z-Wave 2.78]
28-05-2015 22:21:01 | info | write configuration xml file
28-05-2015 22:22:30 | info | AddNodeToNetwork Started
28-05-2015 22:22:30 | info | Controller state: Waiting. Controller is waiting for a user action.
28-05-2015 22:22:30 | debug | Controller is busy: True
28-05-2015 22:22:31 | info | Cancels any in-progress command running on a controller.
28-05-2015 22:22:31 | info | Controller state: Completed. The command has completed successfully.
28-05-2015 22:22:31 | debug | Controller is busy: False
28-05-2015 22:22:32 | info | AddNodeToNetwork Started
28-05-2015 22:22:33 | info | Controller state: Waiting. Controller is waiting for a user action.
28-05-2015 22:22:33 | debug | Controller is busy: True
28-05-2015 22:23:02 | info | Cancels any in-progress command running on a controller.
28-05-2015 22:23:02 | info | Controller state: Completed. The command has completed successfully.
28-05-2015 22:23:02 | debug | Controller is busy: False
28-05-2015 22:23:21 | info | AddNodeToNetwork Started
28-05-2015 22:23:22 | info | Controller state: Starting. The command is starting.
28-05-2015 22:23:22 | debug | Controller is busy: False
28-05-2015 22:38:36 | debug | RequestNodeNeighbourUpdate for node 9
28-05-2015 22:38:42 | debug | TestNetwork node 10
Exception TypeError: TypeError("{'state': 'Sleeping', 'error_msg': 'None.', 'message': 'Controller command is on a sleep queue wait for device.', 'error': 0} is not JSON serializable",) in 'libopenzwave.ctrl_callback' ignored
28-05-2015 22:38:42 | info | Controller state: Sleeping. Controller command is on a sleep queue wait for device.
28-05-2015 22:38:42 | debug | Controller is busy: False
28-05-2015 22:38:57 | info | AddNodeToNetwork Started
28-05-2015 22:38:58 | info | Controller state: Starting. The command is starting.
28-05-2015 22:38:58 | debug | Controller is busy: False
28-05-2015 22:44:27 | info | HealNetwork
28-05-2015 22:44:31 | debug | RequestNodeNeighbourUpdate for node 1
28-05-2015 22:44:48 | error | 404: Not Found http://127.0.0.1:8083/ZWaveAPI/Run/cont ... nformation()
28-05-2015 22:44:51 | debug | RequestNodeInformation node 10
28-05-2015 22:44:51 | debug | RequestNodeInformation node 9
Raspberry Pi 3 + SSD : Jeedom 3.3.19
Dongle Z-Wave : Aeotec Z-Stick Gen 5
Passerrelle 433 Mhz : RFXcom RFXtrx433
Mon matériel
tmartinez
Modérateur
Message par tmartinez » 28 mai 2015, 22:57
il me faudrait les logs du plugin Openzwave aussi stp.
Jeedom sous Proxmox
Mon matériel
alientouch
Message par alientouch » 28 mai 2015, 23:01
ce sont les logs du plugin openzawave (j'en ai un deuxieme openzwave update aussi so ca t'interesse)
Mon matériel
tmartinez
Modérateur
Message par tmartinez » 28 mai 2015, 23:03
oups je me suis trompé. Lorsque tu vas sur le port 8083 tu as quoi ?
Jeedom sous Proxmox
Mon matériel
alientouch
Message par alientouch » 28 mai 2015, 23:04
j'arrive sur le serveur avec en node id 1 mon z-stick s2
Mon matériel
tmartinez
Modérateur
Message par tmartinez » 28 mai 2015, 23:08
je viens de t'envoyer un MP
Jeedom sous Proxmox
Mon matériel
dvb
Message par dvb » 30 mai 2015, 09:47
Jeedom me propose de mettre à jour OpenZwave. J'ai 2 questions :
1/ Quand je vais sur le market, j'ai ce message :
"Attention ce plugin ne semble pas être compatible avec votre système"
J'imagine que c'est destiné aux personnes qui utilisent le serveur zway.
=> Peut-on faire en sorte que ce message ne s'affiche pas systématiquement (pas rassurant...)
2/ Je ne vois pas de changelog.
Est-il possible d'en fournir un systématiquement ?
Très court, juste qu'on sache s'il s'agit de nouvelles fonctionnalités ou de fixes, et lesquels.
D'avance merci.
PS : j'ai quand même mis à jour OpenZwave ;)
DIY 4*2GHz - 4Go RAM - SSD
tmartinez
Modérateur
Message par tmartinez » 30 mai 2015, 09:53
Il n'y a pas de changelog car pas vraiment de changements.
La seule modification est l'adresse de téléchargement de la lib openzwave qui pointe désormais sur notre fork d'openzwave.
Jeedom sous Proxmox
Mon matériel
dvb
Message par dvb » 30 mai 2015, 10:12
dans ce cas ne pas hésiter à le noter.
Je me permets d'insister car c'est rassurant pour l'utilisateur quand on est en prod.
alientouch
Message par alientouch » 30 mai 2015, 11:34
@tmartinez, as tu vu mon MP pour le plugin Zwave stp ?
Mon matériel
Claude69
Message par Claude69 » 31 mai 2015, 10:02
J'ai reçu ma Clé AEON LABS Z-STICK GEN5 et mon hub USB et j'ai acheté le plugin et lors de l'installation j'ai le message pour faire l'installe manuelle:
Capture d’écran 2015-05-31 à 09.56.17.png (58.34 Kio) Consulté 1091 fois
lorsque je lance la commande j'ai la réponse suivante :
NAS-Domotique> wget http://127.0.0.1/jeedom/plugins/openzwa ... es/install
.sh -v -O install.sh; ./install.sh
--2015-05-31 10:00:51-- http://127.0.0.1/jeedom/plugins/openzwa ... install.sh
Connecting to 127.0.0.1:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2015-05-31 10:00:53 ERROR 404: Not Found.
-ash: ./install.sh: Permission denied
Si une âme charitable passe par ici ...
Gestion filtration piscine
Divers éclairages
JEEDOM NUC 3.3.31 ULTIMATE
Mon matériel ici
tmartinez
Modérateur
Message par tmartinez » 31 mai 2015, 11:30
J'ai l'impression que tu es sur un NAS Syno en chroot. As-tu bien lancé le chroot en tapant debian ??
Envoyé de mon iPhone à l'aide de Tapatalk
Jeedom sous Proxmox
Mon matériel
Claude69
Message par Claude69 » 31 mai 2015, 12:12
Le package Debian est bien lancé. Si c'est de ça que tu veux parler.
Divers éclairages
Mon matériel ici
Claude69
Message par Claude69 » 31 mai 2015, 14:12
Le 8088 me permet de copier le fichier, il ne me manque plus que la permission :
NAS-Domotique> wget http://127.0.0.1:8088/jeedom/plugins/op ... sources/in
stall.sh -v -O install.sh; ./install.sh
--2015-05-31 14:10:22-- http://127.0.0.1:8088/jeedom/plugins/op ... install.sh
Connecting to 127.0.0.1:8088... connected.
Length: 2570 (2.5K) [application/octet-stream]
Saving to: 'install.sh'
100%[======================================>] 2,570 --.-K/s in 0s
2015-05-31 14:10:22 (47.3 MB/s) - 'install.sh' saved [2570/2570]
Divers éclairages
Mon matériel ici
tmartinez
Modérateur
Message par tmartinez » 31 mai 2015, 14:16
sudo chmod +x install.sh
Jeedom sous Proxmox
Mon matériel
Claude69
Message par Claude69 » 31 mai 2015, 14:19
non plus
NAS-Domotique> sudo chmod +x install.sh
-ash: sudo: not found
Divers éclairages
Mon matériel ici
tmartinez
Modérateur
Message par tmartinez » 31 mai 2015, 15:17
Sans le sudo alors, je ne connais pas bien les synos
Jeedom sous Proxmox
Mon matériel
yaz.oudj
Message par yaz.oudj » 31 mai 2015, 16:04
Mets toi en super user avec la commande "su"
Ensuite lance la commande : "chmod +x install.sh"
Ensuite "exit" pour ne plus être en super user
Claude69
Message par Claude69 » 31 mai 2015, 19:10
@yaz.oudj Merci ça a l'air d'être passé.
maintenant dans le zwave j'ai :
Capture d’écran 2015-05-31 à 19.09.17.png (18.24 Kio) Consulté 1009 fois
Divers éclairages
Mon matériel ici
