(résolu) Pb instalation dépendances Espeasy
franx
Message par franx » 03 juil. 2018, 17:03
je n'arrive pas à installer les dépendances du plugin Espeasy
je ne maitrise pas vraiment le SSH.
Voici les logs de l'installation
Début de l'installation
converted 'https://raw.githubusercontent.com/lunar ... /nodejs.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/lunar ... /nodejs.sh' (UTF-8)
--2018-07-03 11:21:21-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.120.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.120.133|:443... connected.
Length: 1458 (1.4K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 8.41M=0s
2018-07-03 11:21:21 (8.41 MB/s) - 'dependencies.sh' saved [1458/1458]
Nodejs non installé
Hit http://security.debian.org jessie/updates InRelease
Ign http://http.us.debian.org jessie InRelease
Ign http://httpredir.debian.org jessie InRelease
Get:1 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Hit http://http.us.debian.org jessie Release.gpg
Hit http://httpredir.debian.org jessie Release.gpg
Get:2 https://repo.solid-build.xyz ./ InRelease [354 B]
Ign https://repo.solid-build.xyz ./ InRelease
Get:3 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Get:4 https://repo.solid-build.xyz ./ Release
Get:5 https://repo.solid-build.xyz ./ Release [982 B]
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Get:6 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB]
Get:7 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:8 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Err https://repo.solid-build.xyz ./ Release
Hit http://http.us.debian.org jessie/non-free armhf Packages
Hit http://http.us.debian.org jessie/non-free Translation-en
Get:9 http://httpredir.debian.org jessie/main Sources [7063 kB]
Get:10 http://httpredir.debian.org jessie/main armhf Packages [6675 kB]
Get:11 http://httpredir.debian.org jessie/main Translation-en [4581 kB]
Fetched 162 kB in 1min 15s (2148 B/s)
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repo.solid-build.xyz ./ Release: The following signatures were invalid: KEYEXPIRED 1508672008
W: Failed to fetch https://repo.solid-build.xyz/debian/jes ... /./Release
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
dependencies.sh: 32: [: armv7l: unexpected operator
Utilisation du dépot officiel
## Installing the NodeSource Node.js 8.x LTS Carbon repo...
## Populating apt-get cache...
+ apt-get update
Hit http://httpredir.debian.org jessie-updates InRelease
Get:1 https://repo.solid-build.xyz ./ InRelease [354 B]
Get:2 https://repo.solid-build.xyz ./ Release.gpg [481 B]
Get:4 https://repo.solid-build.xyz ./ Release [982 B]
Get:5 http://httpredir.debian.org jessie-updates/main Sources [17.2 kB]
Get:6 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:7 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Get:8 http://httpredir.debian.org jessie/main Sources [7063 kB]
Get:9 http://httpredir.debian.org jessie/main armhf Packages [6675 kB]
Get:10 http://httpredir.debian.org jessie/main Translation-en [4581 kB]
Fetched 17.0 kB in 1min 11s (238 B/s)
Error executing command, exiting
dependencies.sh: 1: dependencies.sh: nodejs: not found
Version actuelle :
dependencies.sh: 54: dependencies.sh: npm: not found
chown: cannot access 'node_modules': No such file or directory
Fin de l'installation
Merci de votre aide
Franx
Mon install: Mini plus avec disque ssd Msata
Zwave, RfxCom, PLC Bus, Xiaomi,
Franx
rol-rider
Re: Pb instalation dépendances Espeasy
Message par rol-rider » 03 juil. 2018, 18:00
d'après les logs c'est nodejs qu'il n'arrive pas à installer.
j'ai eu ce problème (résolu en SSH)
mais je serais bien incapable de t'aider et de retrouvé ce que j'ai fait !
RPI3 avec mSATA
vincenzi1
Message par vincenzi1 » 04 juil. 2018, 14:43
tu a un problème de signature des packet
tu fait en SSH sous root
curl https://repo.solid-build.xyz/debian/jessie/bsp-imx6/Release.key | sudo apt-key add -
et après tu relance t'es dépendance
franx
Message par franx » 04 juil. 2018, 16:17
Merci pour ta réponse,
je galère pour arriver a me connecter en ssh sur mon jeedom.
des que j'y arrive je test ça
Franx
rol-rider
Message par rol-rider » 04 juil. 2018, 16:50
il y a eu une mise à jour sur le plugin espeasy, tu peux toujours faire la mise à jour et retester....on c'est jamais.
RPI3 avec mSATA
franx
Message par franx » 04 juil. 2018, 18:13
La mise a jour n'a rien changer pour moi.
il faut que j'arrive a me connecter en SSH mais je n'y comprend pas grand chose. ça ne passe pas avec jeedom et Mjeedom96
Franx
vincenzi1
Message par vincenzi1 » 04 juil. 2018, 19:03
utilise putty
franx
Message par franx » 04 juil. 2018, 19:11
ok pour Putty mais j'ultilise quoi comme nom d'utilisateur et mot de passe ?
Franx
vincenzi1
Message par vincenzi1 » 04 juil. 2018, 20:40
ta quoi comme distribution ?
franx
Message par franx » 04 juil. 2018, 20:55
Voila ce que me donne l'onglet Health
Linux linux 3.14.79-fslc-imx6-sr #1 SMP Wed Sep 13 12:05:55 UTC 2017 armv7l GNU/Linux [8.9]
Franx
vincenzi1
Message par vincenzi1 » 04 juil. 2018, 22:51
sa me donne pas grande chose
juste que sa tourne sur ARM un Raspberry ?
tu la installer comment ton jeedom ?
franx
Message par franx » 04 juil. 2018, 22:59
C'est une box mini + avec un disque ssd . j'ai tout reinstallé il y a 2 mois environs avec une image Miniplus V 3.1.7 jessie
Franx
vincenzi1
Message par vincenzi1 » 04 juil. 2018, 23:06
ok donc par défaut c'est
pseudo: root
password: debian
rol-rider
Message par rol-rider » 04 juil. 2018, 23:15
c'est les images réalisé par bronche ?
il y a les codes dans son fichier lisez moi
ça semble être en SSH debian et debian et pour root debian
Une image pour humingboard Mini plus - Jessie et Jeedom 3.1.7 (SSH: debian / debian - root / debian - jeedom admin -admin)
RPI3 avec mSATA
franx
Message par franx » 04 juil. 2018, 23:18
Merci à tous les 2, j’essaie ça demain
Franx
franx
Franx
franx
Message par franx » 05 juil. 2018, 08:31
on avance, j'arrive a me connecter en ssh avec debian debian avec putty.
par contre comment je sais si je suis en root avec ce login ?
Franx
rol-rider
Message par rol-rider » 05 juil. 2018, 08:43
Ba, là tu ne dois pas y être.
Quand tu fais un sudo...... Il va te demander le MDP Root.
Mais, quand tu auras résolu ton problème, il serait souhaitable de modifier les MDP.
RPI3 avec mSATA
franx
Message par franx » 05 juil. 2018, 08:58
C'est ok pour la connexion en SSH, j'ai passé la commande curl https://repo.solid-build.xyz/debian/jes ... elease.key | sudo apt-key add -
Il m'a redemandé le mdp a la fin pour le sudo, Nickel.
par contre j'ai relancé les dépendances apres mais l'install n'aboutit pas.
je vous joint les logs
Accueil
Analyse
Outils
Plugins
1
08:57:14
Gestion
Mode inclusion
Configuration
Santé
Mes espeasy
Aucun espeasy détecté, démarrer un node pour ajout
Configuration du plugin
ESPeasy (espeasy) - stable
Etat
StatutActifAction
Version2018-07-03 01:18:21 Version Jeedom2.4
Auteurlunarok LicenseAGPL
Log
Niveau de log localAucunDefautDebugInfoWarningError
Logs
Dépendances
Nom Statut Installation Dernière installation
Local NOK 2018-06-19 22:28:09
Démon
Nom Statut Configuration (Re)Démarrer Arrêter Gestion automatique Dernier lancement
Local NOK NOK Gestion automatique désactivée Inconnue
Configuration
IP Controleur à saisir dans ESPeasy (onglet config) : 192.168.0.145
Port Controleur à saisir dans ESPeasy (onglet config) : 8121
Publish template à saisir dans ESPeasy (onglet tools, puis bouton advanced) :device=%sysname%&taskid=%id%&cmd=%valname%&value=%value%
Fonctionnalités
interactNon
cronNon
cron5Non
cron15Non
cron30Non
cronHourlyNon
cronDailyNon
Log du plugin
Rechercher
--2018-07-05 06:51:06-- https://raw.githubusercontent.com/lunar ... /nodejs.sh
0K . 100% 10.1M=0s
2018-07-05 06:51:06 (10.1 MB/s) - 'dependencies.sh' saved [1458/1458]
Nodejs non installé
Hit https://repo.solid-build.xyz ./ Release.gpg
Hit http://httpredir.debian.org jessie-updates/main Sources
Get:2 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:3 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Hit https://repo.solid-build.xyz ./ Sources
Hit https://repo.solid-build.xyz ./ Packages
Hit http://httpredir.debian.org jessie/main Sources
Get:4 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:5 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:6 https://repo.solid-build.xyz ./ Translation-en [351 B]
Hit http://httpredir.debian.org jessie/main armhf Packages
Get:7 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:8 https://repo.solid-build.xyz ./ Translation-en [351 B]
Ign https://repo.solid-build.xyz ./ Translation-en
Hit http://httpredir.debian.org jessie/main Translation-en
Fetched 15.5 kB in 32s (484 B/s)
+ apt-get update
Get:2 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:3 https://repo.solid-build.xyz ./ Translation-en [351 B]
Get:5 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Fetched 15.5 kB in 32s (477 B/s)
Version actuelle :
Franx
vincenzi1
Message par vincenzi1 » 05 juil. 2018, 09:15
ok
fait
