maccaire
Re: [Sujet officiel] l'assistant vocal Snips 100% privé (Plugin développé pour jeedom)
Message par maccaire » 13 nov. 2018, 09:14
Je suis bloque a l'installation de sam init, j'ai l'erreur suivante:
✖ Error setting up virtualenv, one or more actions might not be able to run. Reason :
Could not find a version that satisfies the requirement hermes_python==0.1.18 (from -r requirements.txt (line 1)) (from versions: 0.1.19, 0.1.24)
No matching distribution found for hermes_python==0.1.18 (from -r requirements.txt (line 1))
J'ai aussi un soucis sur l'installation du plugin les dependances ne se lancent pas mais les demons sont OK les commandes ne s’affichent pas .
voici la fin du log des dependances:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libmosquitto-dev : Depends: libmosquitto1 (>= 1.5.4-0mosquitto1) but 1.5.3-0mosquitto1~jessie1 is to be installed
mosquitto : Depends: libssl1.1 (>= 1.1.0) but it is not installable
Depends: libwebsockets8 (>= 1.6.0) but it is not installable
mosquitto-clients : Depends: libmosquitto1 (= 1.5.4-0mosquitto1) but 1.5.3-0mosquitto1~jessie1 is to be installed
E: Unable to correct problems, you have held broken packages.
Reading package lists...
Building dependency tree...
Reading state information...
php5-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
mkdir: cannot create directory '/tmp/jeedom/snips': File exists
Dependances installation is done
Ou est le pb ?
joesab
Message par joesab » 13 nov. 2018, 19:48
Jeandhom a écrit :
12 nov. 2018, 21:07
joesab a écrit :
12 nov. 2018, 17:21
Jeandhom a écrit :
11 nov. 2018, 20:24
rpi_update n'est pas une bonne idée.
Certainement un problème d'installation des drivers de seeed2micvoicec avec le dernier firmware et le dernier kernel du pi.
Une réinstall classique des drivers risque de ne pas fonctionner.
Il vaut mieux rester sous la version 4.14.71-v7+
bonjour
comment faire marche arrière ?
sabine
Même en faisant machine arrière -> 4.14.71-v7+, les scripts d'installation du driver ne savent pas faire.
bonsoir
effectivement la "marche arrière" n'a pas été très efficace.
une remise à zéro a été efficace
merci à ce forum qui nous aide énormément !
sabine
maccaire
Message par maccaire » 14 nov. 2018, 10:46
J'avance difficilement car je ne comprends pas la philosophie de l'installation. Installation de snips sur raspberrypi zero c'est bon, ensuite deployer l'installation avec sam sur un autre périphérique, j'ai choisi le raspberry pi3 qui héberge jeedom mais c'est la catastrophe les lignes de codes sont en rouges. Je decide de deployer sur le meme raspberry que snips et la cela fonctionne. J'ai creer l'assistant avec sam-intall ok, je teste le micro et hp c'est ok, sam status ok mais sam watch ne veux rien savoir.
pi@raspberrypi:~ $ sam watch
[10:24:44] Watching on localhost:1883 (MQTT)
je demande "hey snips" mais rien ne s'affiche, j'ai du rater une étape !!!
GargouilleBL
Message par GargouilleBL » 14 nov. 2018, 12:05
@ maccaire, vérifie sur la console Snips où tu a créer ton assistant si le hotword est bien "Hey Snips", (en haut à gauche) j'ai eu la blague qu'il était sur personnalisé.
Et puis ensuite même avec "Hey snips" configuré, chez moi il ne le reconnaissait pas, j'ai mis "Jarvis" et hop sam watch c'est rempli ;-)
@+GargouilleBL
maccaire
Message par maccaire » 14 nov. 2018, 13:24
je vais essaye Jarvis
maccaire
Message par maccaire » 14 nov. 2018, 13:26
avec tout mes essais j'ai planté jeedom qui ne redemarre pas!!!!!
GargouilleBL
Message par GargouilleBL » 14 nov. 2018, 13:46
Restore le backup de cette nuit
maccaire
Message par maccaire » 14 nov. 2018, 16:11
C'est bon jeedom est revenu a l'etat initial cet a dire toujours sans les dependances NOK mais demarre OK mais rien dans les commandes, seulement snips devices (default) et Intents (Response by Jeedom) non configurable.
snips et jarvis toujours sourd et muet.
maccaire
Message par maccaire » 14 nov. 2018, 16:16
le log du plugin snips
[2018-11-14 15:29:31][ERROR] : Erreur sur snips::mqttClient() : Class 'Mosquitto\Client' not found
[2018-11-14 15:29:54][ERROR] : Erreur sur la fonction deamon_start du plugin : Vous devez attendre au moins 45 secondes entre deux lancements du démon. Dernier lancement : 2018-11-14 15:29:29
[2018-11-14 15:31:10][ERROR] : Erreur sur snips::mqttClient() : Class 'Mosquitto\Client' not found
[2018-11-14 15:31:59][ERROR] : Erreur sur snips::mqttClient() : Class 'Mosquitto\Client' not found
Le log dependances
Start to install dependances
lsb-release is already the newest version.
php-pear is already the newest version.
The following packages were automatically installed and are no longer required:
libev4 libuv1 libwebsockets8
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 810 not upgraded.
Ign http://deb.gateweb.fr gateweb InRelease
Ign http://deb.gateweb.fr gateweb Release.gpg
Ign http://ftp.de.debian.org stretch InRelease
Hit http://deb.gateweb.fr gateweb Release
Hit http://ftp.de.debian.org stretch Release.gpg
Ign http://http.us.debian.org jessie InRelease
Ign http://deb.gateweb.fr gateweb/main armhf Packages/DiffIndex
Hit http://security.debian.org jessie/updates InRelease
Ign http://httpredir.debian.org jessie InRelease
Hit http://http.us.debian.org jessie Release.gpg
Get:1 http://httpredir.debian.org jessie-updates InRelease [145 kB]
Hit http://deb.gateweb.fr gateweb/main armhf Packages
Get:2 https://repo.solid-build.xyz ./ InRelease [169 B]
Ign https://repo.solid-build.xyz ./ InRelease
Hit https://repo.mosquitto.org jessie InRelease
Hit https://deb.nodesource.com jessie InRelease
Ign http://deb.gateweb.fr gateweb/main Translation-en
Hit http://httpredir.debian.org jessie Release.gpg
Hit https://repo.solid-build.xyz ./ Release.gpg
Hit http://ftp.de.debian.org stretch/main armhf Packages
Hit http://ftp.de.debian.org stretch/non-free armhf Packages
Hit http://ftp.de.debian.org stretch/main Translation-en
Hit http://ftp.de.debian.org stretch/non-free Translation-en
Hit http://security.debian.org jessie/updates/main Sources
Hit http://security.debian.org jessie/updates/main armhf Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://http.us.debian.org jessie/non-free armhf Packages
Hit http://http.us.debian.org jessie/non-free Translation-en
Hit http://httpredir.debian.org jessie-updates/main Sources
Get:3 http://httpredir.debian.org jessie-updates/main armhf Packages/DiffIndex [11.8 kB]
Get:4 http://httpredir.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Hit https://repo.mosquitto.org jessie/main armhf Packages
Get:5 https://repo.mosquitto.org jessie/main Translation-en [178 B]
Get:6 https://repo.mosquitto.org jessie/main Translation-en [178 B]
Get:7 https://repo.mosquitto.org jessie/main Translation-en [178 B]
Get:8 https://repo.mosquitto.org jessie/main Translation-en [178 B]
Get:9 https://repo.mosquitto.org jessie/main Translation-en [178 B]
Ign https://repo.mosquitto.org jessie/main Translation-en
Hit https://deb.nodesource.com jessie/main Sources
Hit https://deb.nodesource.com jessie/main armhf Packages
Get:10 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:11 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:12 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:13 https://deb.nodesource.com jessie/main Translation-en [162 B]
Get:14 https://deb.nodesource.com jessie/main Translation-en [162 B]
Ign https://deb.nodesource.com jessie/main Translation-en
Hit https://repo.solid-build.xyz ./ Sources
Hit https://repo.solid-build.xyz ./ Packages
Get:15 https://repo.solid-build.xyz ./ Translation-en [169 B]
Get:16 https://repo.solid-build.xyz ./ Translation-en [169 B]
Get:17 https://repo.solid-build.xyz ./ Translation-en [169 B]
Get:18 https://repo.solid-build.xyz ./ Translation-en [169 B]
Get:19 https://repo.solid-build.xyz ./ Translation-en [169 B]
Ign https://repo.solid-build.xyz ./ Translation-en
Hit http://httpredir.debian.org jessie/main Sources
Hit http://httpredir.debian.org jessie/main armhf Packages
Hit http://httpredir.debian.org jessie/main Translation-en
Jeandhom
Message par Jeandhom » 14 nov. 2018, 16:24
C'est horrible ce mélange de jessie et stretch.
Tu as du ajouter les 2 sources dans /etc/apt/sources.list.
Tu coures à la catastrophe.
benj29
Message par benj29 » 14 nov. 2018, 16:44
Bonsoir, @valentin.
Je tourne avec pihole pour mes DNS et le nettoyage de pub.
Je découvre que visiblement ma machine SNIPS (serveur) est visiblement très très verbeuse.
En sachant qu'il n'y a que ça dessus...
Il s'agit de la 2.93.
Pour quelles raisons ? Je vois de nombreux appels à atomic.snips.com.
Je présume que c'est normal d'appeler le serveur snips, mais en l'occurence, moi mon serveur n'est pas en place (aucun satellite à ce stade) et donc tourne juste dans le vide.
maccaire
Message par maccaire » 14 nov. 2018, 17:17
J'ai modifie mon fichier sources.list pour ne garder que jessie. pour le php je suis php7 et vous parlez toujours de php 5 lequel est préconise pour mosquitto ?
GargouilleBL
Message par GargouilleBL » 14 nov. 2018, 21:37
Merci à tous le monde, cela fonctionne enfin, plus qu'a configurer mes Intents
Pour info, la solution se trouve sur le forum de Snips : https://forum.snips.ai/t/installation-p ... ssible/686
Encore merci et plus particulièrement à @coorfang (auteur du plugin ?) et @Jeandhom
@+GargouilleBL
Hydro
Message par Hydro » 15 nov. 2018, 22:52
Bonsoir.
J'ai résolu mon problème d'installation sur debian 9 grâce a une personne du forum snips.
Sur debian il ne faut pas faire Sam init qui modifie les sources pour celles raspian.
Il faut donc faire a la main ce que fait Sam init.
Je vous mets le lien de la discussion :
https://forum.snips.ai/t/install-on-debian-9-vm/660/10
Dommage que cela n'est pas indiqué dans la documentation.
Envoyé de mon ONEPLUS A3003 en utilisant Tapatalk
maccaire
Message par maccaire » 16 nov. 2018, 12:29
Pour installer les dependances snips, jedom est il en php 5 ou 7 ?
maccaire
Message par maccaire » 16 nov. 2018, 12:35
Mon chemin est le suivant: /etc/php/7.0 et dedans 2 répertoires: cli et mods-available sont ils correct ?
maccaire
Message par maccaire » 16 nov. 2018, 12:53
Encore une question existe t il un point commun entre le le plugin mqtt et snips ?
gaudouy
Message par gaudouy » 16 nov. 2018, 13:33
Savez vous si il est possible de Hacker un Google home mini et de s en servir comme satellite pour snips ?
Hydro
Message par Hydro » 17 nov. 2018, 09:29
Des personnes utilise le respeaker V2 ?
benj29
Message par benj29 » 17 nov. 2018, 09:31
Hydro a écrit :Des personnes utilise le respeaker V2 ?
Oui, la même question a été posée deux pages avant et encore avant...
Utilisateurs parcourant ce forum : Merangle et 6 invités
