[Plugin Tiers][Sujet Principal] Kroomba
ValentinD
Re: [Plugin Tiers][Sujet Principal] Kroomba
Message par ValentinD » 06 juil. 2019, 17:34
Bonjour, j'ai également un problème avec les dépendance :
The directory '/var/www/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Not uninstalling six at /usr/lib/python2.7/dist-packages, outside environment /usr
The directory '/var/www/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting six
Downloading https://files.pythonhosted.org/packages/73/fb/00a976f728d0d1fecfe898238ce23f502a721c0ac0ecfedb80e0d88c64e9/six-1.12.0-py2.py3-none-any.whl
Installing collected packages: six
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 360, in run
prefix=options.prefix_path,
File "/usr/lib/python2.7/dist-packages/pip/req/req_set.py", line 784, in install
**kwargs
File "/usr/lib/python2.7/dist-packages/pip/req/req_install.py", line 851, in install
self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File "/usr/lib/python2.7/dist-packages/pip/req/req_install.py", line 1064, in move_wheel_files
isolated=self.isolated,
File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 247, in move_wheel_files
prefix=prefix,
File "/usr/lib/python2.7/dist-packages/pip/locations.py", line 153, in distutils_scheme
i.finalize_options()
File "/usr/lib/python2.7/distutils/command/install.py", line 357, in finalize_options
self.create_home_path()
File "/usr/lib/python2.7/distutils/command/install.py", line 593, in create_home_path
os.makedirs(path, 0700)
File "/usr/lib/python2.7/os.py", line 150, in makedirs
makedirs(head, mode)
File "/usr/lib/python2.7/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/var/www/.local'
Cannot uninstall requirement paho-mqtt, not installed
Collecting paho-mqtt
Downloading https://files.pythonhosted.org/packages/25/63/db25e62979c2a716a74950c9ed658dce431b5cb01fde29eb6cba9489a904/paho-mqtt-1.4.0.tar.gz (88kB)
Installing collected packages: paho-mqtt
Running setup.py install for paho-mqtt: started
Running setup.py install for paho-mqtt: finished with status 'error'
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-xo0t4d/paho-mqtt/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-45vN77-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
running install
error: [Errno 13] Permission denied: '/var/www/.local'
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-xo0t4d/paho-mqtt/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('
');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-45vN77-record/install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-xo0t4d/paho-mqtt/
Cloning into 'Roomba980-Python'...
Tommaximmo
Message par Tommaximmo » 07 juil. 2019, 20:16
Meme soucis pour moi qui a déjà été vu au début de cette discussion et qui se résoud par les commandes suivantes.
sudo mkdir -p /var/www/.local
sudo mkdir -p /var/www/.pip
sudo chown www-data:www-data /var/www/.local
sudo chown www-data:www-data /var/www/.pip
Pas encore testé dans le détail mais cela semble finalement ok pour moi également.
BB2A
Message par BB2A » 29 juil. 2019, 10:32
snoopy10800 a écrit :
22 juin 2019, 17:40
je devrais bientôt acheter un Roomba 960.
J'aimerais utiliser Jeedom pour lancer le robot pendant nos heures de boulot. J'ai donc juste besoin d'envoyer un ordre pour le démarrer.
Vous me confirmez que le plugin fonctionne correctement pour ça ?
Oui parfaitement c'est ce que je fait!
Un scénario avec déclenchement tout les jours à une heure précise et je regarde si on est présent si absent alors démarrage de roomba.
Merci JEEDOM
BB2A
Message par BB2A » 29 juil. 2019, 10:56
Impeccable pour moi après réinstallation de mon système j'avais le même problème et les commandes l'on résolu
Merci JEEDOM
jiminy
Message par jiminy » 15 août 2019, 09:43
Bonjour à tous, juste ce petit message pour dire que j'utilise la version beta du plugin pour le rendre compatible avec la future version 4 de Jeedom.
Normalement cette version beta doit aussi fonctionner avec Jeedom v.3.3.29 mais par contre attention si votre Jeedom est dans une version 3 plus ancienne surtout n'utilisez pas cette version beta (ou mieux mettez à jour votre Jeedom en version 3.3.29 !!).
