cairve
Message par cairve » 22 févr. 2019, 23:11
j'ai acheté la double prise, mais malgrés le faite de l'avoir mise sur une IP fixe, et d'avoir les 2 ID, la prise ne fonctionne pas avec le plugin.
j'ai la version 2019-02-19 04:26:30 du plugin.
Voici le log sur un ON et un OFF (répétition de la commande sur 6x):
[2019-02-22 23:10:09][DEBUG] : CFGcanal:6
[2019-02-22 23:10:09][DEBUG] : Commande : {"t":"1550873409","devId":"66376420ecfabc2a897d","dps":{"1":true},"uid":""}
[2019-02-22 23:10:09][DEBUG] : try to connect to : 192.168.0.69  6668
[2019-02-22 23:10:09][DEBUG] : Connect OK
[2019-02-22 23:10:10][DEBUG] : Return Out size: 0
[2019-02-22 23:10:10][DEBUG] : return empty
[2019-02-22 23:10:10][DEBUG] : Commande : {"gwId":"66376420ecfabc2a897d","devId":"66376420ecfabc2a897d"}
[2019-02-22 23:10:10][DEBUG] : try to connect to : 192.168.0.69  6668
[2019-02-22 23:10:10][DEBUG] : Connect OK
[2019-02-22 23:10:10][DEBUG] : Return Out size: 173
[2019-02-22 23:10:10][DEBUG] : return OK :0
[2019-02-22 23:10:10][DEBUG] : length:157
[2019-02-22 23:10:10][DEBUG] : len of decoded returned mess:145
[2019-02-22 23:10:10][DEBUG] : return decoded : {"devId":"66376420ecfabc2a897d","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2296,"21":1,"22":596,"23":28361,"24":15968,"25":1310}}
[2019-02-22 23:10:10][DEBUG] : Read Json OK
[2019-02-22 23:10:10][DEBUG] : Not null
[2019-02-22 23:10:10][DEBUG] : OFF
[2019-02-22 23:10:12][DEBUG] : CFGcanal:6
[2019-02-22 23:10:12][DEBUG] : Commande : {"t":"1550873412","devId":"66376420ecfabc2a897d","dps":{"1":false},"uid":""}
[2019-02-22 23:10:12][DEBUG] : try to connect to : 192.168.0.69  6668
[2019-02-22 23:10:12][DEBUG] : Connect OK
[2019-02-22 23:10:12][DEBUG] : Return Out size: 0
[2019-02-22 23:10:12][DEBUG] : return empty
[2019-02-22 23:10:12][DEBUG] : Commande : {"gwId":"66376420ecfabc2a897d","devId":"66376420ecfabc2a897d"}
[2019-02-22 23:10:12][DEBUG] : Return Out size: 173
[2019-02-22 23:10:12][DEBUG] : return OK :0
[2019-02-22 23:10:12][DEBUG] : length:157
[2019-02-22 23:10:12][DEBUG] : len of decoded returned mess:145
[2019-02-22 23:10:12][DEBUG] : return decoded : {"devId":"66376420ecfabc2a897d","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2296,"21":1,"22":596,"23":28361,"24":15968,"25":1310}}
[2019-02-22 23:10:12][DEBUG] : Read Json OK
[2019-02-22 23:10:12][DEBUG] : Not null
[2019-02-22 23:10:12][DEBUG] : OFF
Merci d'avance pour toute aide :)
Jeedom RPI3 / SSD 16Go
clé zigate 3.0f (40), clé zwave (25), clé 3G, 2 xiaomi Mi Home (30), Philips Hue (2), espeasy wifi (12), wifilight2 (2), blea (local + 1 déporté sur RPI2) + 2 Dafang custom
Awtrix 2.0, Logitech Harmony Elite
70 scénarios
bcaro
Message par bcaro » 23 févr. 2019, 08:46
vérifier que le Jeton fait 16 caractères et qu'il n'y a pas d'espace dans le champ de saisie.
La prise est accessible, on récupère même la consommation (config 20 pour la tension)
C'est forcément un souci de jeton (l'iD est correct par contre)
Debian DIY Jessie
30 ampoules
Rfxcom : 20 modules
Mysensors : 24 nœuds
Téléinfo
Z wave : 15 modules
maaaanuuuu
Message par maaaanuuuu » 25 févr. 2019, 09:26
j'ai le meme pb que cairve avec une multiprise yuanguo 4+2 USB
[2019-02-25 09:19:20][DEBUG] : CFGcanal:6
[2019-02-25 09:19:20][DEBUG] : Commande : {"t":"1551082760","devId":"37315766840d8e8e0a87","dps":{"5":true},"uid":""}
[2019-02-25 09:19:20][DEBUG] : try to connect to : 172.16.xx.yy 6668
[2019-02-25 09:19:20][DEBUG] : Connect OK
[2019-02-25 09:19:20][DEBUG] : Return Out size: 0
[2019-02-25 09:19:20][DEBUG] : return empty
[2019-02-25 09:19:24][DEBUG] : CFGcanal:6
[2019-02-25 09:19:24][DEBUG] : Commande : {"t":"1551082764","devId":"37315766840d8e8e0a87","dps":{"5":false},"uid":""}
[2019-02-25 09:19:24][DEBUG] : try to connect to : 172.16.xx.yy 6668
[2019-02-25 09:19:24][DEBUG] : Connect OK
[2019-02-25 09:19:25][DEBUG] : Return Out size: 0
[2019-02-25 09:19:25][DEBUG] : return empty
[2019-02-25 09:19:28][DEBUG] : CFGcanal:6
[2019-02-25 09:19:28][DEBUG] : Commande : {"t":"1551082768","devId":"37315766840d8e8e0a87","dps":{"5":true},"uid":""}
[2019-02-25 09:19:28][DEBUG] : try to connect to : 172.16.xx.yy 6668
[2019-02-25 09:19:28][DEBUG] : Connect OK
[2019-02-25 09:19:28][DEBUG] : Return Out size: 0
[2019-02-25 09:19:28][DEBUG] : return empty
[2019-02-25 09:20:01][INFO] : !!************************** Start cron update WifilightV2 *******************************!!
[2019-02-25 09:20:01][INFO] : <<<<<<< Device: yuyu - Class: Tuya_SW_5>>>>>>>
[2019-02-25 09:20:01][DEBUG] : Connected:-1
[2019-02-25 09:20:01][INFO] : !!************************** End cron update WifilightV2 *******************************!!
Que veut dire la commande "CFGcanal:6" ?
cairve
Message par cairve » 25 févr. 2019, 09:50
D'abord, javais fait l'essai en mettant la vieille version de l'appli Smart life et le téléphone connecté sur le pc en debug.
J'avais pas du récupéré le bon ID.
Puis je suis passé par l'application Packet Capture
Perso, j'ai eu du mal à trouver le bon ID de jeton dans les log reçus.
Dans ce que tu récupères, il faut regarder les JSON, et c'est dans un JSON commençant par
    "resultat"
Le jeton correspond à la valeur de "localKey" (vers la fin du JSON)
L'identifiant correspond à la valeur de "devId", "uuid" ou "id".
J'espère que tu y arriveras
70 scénarios
maaaanuuuu
Message par maaaanuuuu » 25 févr. 2019, 09:52
je vais voir ça :)
maaaanuuuu
Message par maaaanuuuu » 26 févr. 2019, 14:02
    "resultat"
C'est tout bon ;)
MErci
cairve
Message par cairve » 26 févr. 2019, 14:22
De rien :)
70 scénarios
darkmoon
Message par darkmoon » 28 févr. 2019, 06:59
bonjour, ma question est simple :
sur les prises wifi tuya munies d'un port usb...
est il possible de piloter le port usb en "on" ou "off" indépendamment de la prise électrique ???
c'est dans le but de pouvoir controler une alimentation usb...
merci pour votre réponse
cordialement
NUC NUC7I3BNH / ssd M2 256go / 8go Crucial vengeance DDR4
Jeedom V3.2.16 sur Debian 9
Plugins : Z-wave / rfx-com / xiaomi / blea / dialogflow
etc...
bcaro
Message par bcaro » 02 mars 2019, 07:06
@darkmoon : oui
@tous : avez vous testé les prises neocoolcam ?
Debian DIY Jessie
30 ampoules
Rfxcom : 20 modules
Téléinfo
Z wave : 15 modules
cairve
Message par cairve » 02 mars 2019, 07:47
neo coolcam c'est pas que du zwave ?
70 scénarios
Titof2375
Message par Titof2375 » 02 mars 2019, 08:49
cairve a écrit :
02 mars 2019, 07:47
Il y en a en wifi et en zwave.j ai posse même question la semaine derrière et personne de ma répondu
Rpi 3 avec jeedom
cairve
Message par cairve » 02 mars 2019, 13:45
Ha, je ne savais pas.
Donc jamais essayé ...
70 scénarios
thierry38090
Message par thierry38090 » 02 mars 2019, 15:33
Je suis nouveau dans cette chouette communauté Jeedom et commence à mettre en place mon système domotique.
Actuellement abonné au service Home by SFR je suis en train de monter un nouveau système propre que je puisse contrôler du bout des doigts !
J'ai donc installé Jeedom sur un Raspberry PI 2 et je butte actuellement sur un problème avec mes prises connectées.
J'ai 10 prises pilotables avec l'application eTuya / SmartLife et aussi avec Alexa.
J'ai réussi à les ajouter à mon installation Jeedom après avoir récupéré les identifiants et clés mais voici mon problème :
les prises ne donnent jamais leur état réel actuel.
Si je les allume ou les éteins via Jeedom c'est ok, l'état se met bien à jour, mais si elles sont allumées ou éteintes via Alexa, dans Jeedom elles affichent toujours leur état précédent, le dernier connu de Jeedom.
J'ai fait le test en supprimant une prise et en la recréant, lorsque je vais dans les propriétés de la commande Etat (SwOnOffGet) je n'ai aucune valeur ni date de collecte.
Ceci semble montrer que le plugin WifilightV2 n'interroge jamais les prises sur leur état actuel.
Lorsque j'active les logs sur le plugin, je vois toutes les minutes une interrogation de l'état connecté qui renvoie -1 pour toutes les prises, ce qui semble une valeur correcte, mais aucune commande de demande d'état ne semble envoyée.
Avez-vous une idée parce que là je sèche depuis 3 jours...
korben40
Message par korben40 » 02 mars 2019, 16:23
j'ai suivi plusieurs tuto pour connecter ma prise wifi smartlight mais sans succès.
La prise est la suivante : https://www.amazon.fr/gp/product/B078S6 ... UTF8&psc=1
Voici en pièces jointe les logs et screenshots de ma conf.
Quelqu'un peut me dire ce que je fais mal ?
Merci par avance.
bcaro
Message par bcaro » 02 mars 2019, 16:53
@ thierry38090
le retour d'état a été supprimé car provoque des microcoupures.
Il est conservé avec les prises avec conso 1 ou 2 plugs, utilise cette config si tu veux.
je viens de pousser une nouvelle version avec retour d'état pour les prises 4 et 5 mais il faut l'enlever en cas de microcoupure
doc modifiée en ce sens
@korben40
lire ce fil, en tous cas cette prise est compatible
Debian DIY Jessie
30 ampoules
Rfxcom : 20 modules
Téléinfo
Z wave : 15 modules
korben40
Message par korben40 » 02 mars 2019, 19:53
Bon je me réponds tout seul, pour récupérer la " key" , il faut suivre ce tuto :
https://github.com/codetheweb/tuyapi/bl ... s/SETUP.md
thierry38090
Message par thierry38090 » 03 mars 2019, 00:06
@bcaro
Merci beaucoup, ça fonctionne parfaitement avec le type conso 1 plug, merci !!!
AlphaTM91
Message par AlphaTM91 » 08 mars 2019, 09:38
Salut Bcaro
Je viens d'ajouter ma multiprise KOOGEEK, mis l'ID et la KEY tout marche bien sauf que je n'est que 1 prise dans les commandes (la prise 1)
Comment faire pour avoir le on off du général et ceux des prise 2 3 4 et USB
J'ai testé de les créé moi meme avec les commande 202 203 204...etc mais ca marche pas
Peux tu m'envoyer une copie d’écran des commandes a créer ou me dire comment les faire générer automatiquement
merci d'avance
bcaro
Message par bcaro » 08 mars 2019, 14:17
tu crées 5 prises 4 + usb et attribution des canaux 1 2 3 4 5
aucune solution via des commandes à créer, ça ne marchera pas.
maintenant pour le ON/OFF général, je ne sais pas comment faire.
Debian DIY Jessie
30 ampoules
Rfxcom : 20 modules
Téléinfo
Z wave : 15 modules
thierry38090
Message par thierry38090 » 11 mars 2019, 10:06
J'ai commencé mon installation avec Jeedom en ajoutant des détecteurs d'ouverture et des prises connectées.
Désormais je bute sur l'ajout des commandes de volet roulant filaires.
Celles-ci sont de type Wifi, connectées à une application Smart Life.
Lorsque j'ai ajouté mes prises connectées avec le plugin WifiLightv2, la détection des identifiants et clés a fait également apparaître mes commandes de volet roulant, je dispose donc de leur adresse IP fixe (au travers de mon routeur) ainsi que leur identifiant et localKey.
Je pense qu'il serait donc possible de les contrôler au travers de ce plugin mais je n'y parviens pas.
Merci pour votre aide !
Thierry
