Toujours des difficultés pour réinstaller le pluging Zibasedom sur une smart
J'ai essayer "curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -" mais sans succès
Voici le log de débug
Début de l'installation
/var/www/html/plugins/Zibasedom/resources/nodejs.sh: line 15: nodejs: command not found
Version actuelle :
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Reading package lists...
Building dependency tree...
Reading state information...
Package 'npm' is not installed, so not removed
Package 'nodejs' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 146 not upgraded.
converted 'http://dietpi.com/downloads/binaries/c2 ... _arm64.deb' (ANSI_X3.4-1968) -> 'http://dietpi.com/downloads/binaries/c2 ... _arm64.deb' (UTF-8)
--2018-07-29 06:18:19-- http://dietpi.com/downloads/binaries/c2 ... _arm64.deb
Resolving dietpi.com (dietpi.com)... 185.101.93.93
Connecting to dietpi.com (dietpi.com)|185.101.93.93|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://dietpi.com/downloads/binaries/c ... _arm64.deb [following]
converted 'https://dietpi.com/downloads/binaries/c ... _arm64.deb' (ANSI_X3.4-1968) -> 'https://dietpi.com/downloads/binaries/c ... _arm64.deb' (UTF-8)
--2018-07-29 06:18:19-- https://dietpi.com/downloads/binaries/c ... _arm64.deb
Connecting to dietpi.com (dietpi.com)|185.101.93.93|:443... connected.
HTTP request sent, awaiting response... 404 Not Found
2018-07-29 06:18:20 ERROR 404: Not Found.
dpkg: error processing archive nodejs_5-1_arm64.deb (--install):
cannot access archive: No such file or directory
Errors were encountered while processing:
ln: failed to create symbolic link '/usr/local/bin/nodejs': File exists
rm: cannot remove 'nodejs_5-1_arm64.deb': No such file or directory
/var/www/html/plugins/Zibasedom/resources/nodejs.sh: line 52: nodejs: command not found
Version actuelle :
/var/www/html/plugins/Zibasedom/resources/nodejs.sh: line 59: npm: command not found
sudo: npm: command not found
chmod: cannot access 'bridge': No such file or directory
Fin de l'installation
Auriez vous une idée
Pour résumer :
Courtoisie, amabilité, politesse et bonne humeur sont les maîtres mots pour un forum sympathique, bienveillant et accueillant
Pour résumer :
Plugin ZIBASEDOM
- magicgg91
- Actif
- Contact :
Re: Plugin ZIBASEDOM
Un plugin DOIT gérer ses dépendances. Tu ne dois rien avoir à installer manuellement normalement, et encore moins node, car c'est le meilleur moyen de foutre le bordel sur ton Jeedom...
DomoPi - Mon site dédié au Raspberry Pi et à la domotique
Je n'arrive pas installer la dépendance, comment faire ?
Voici le log d'instal
Version actuelle :
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
--2018-08-04 17:35:05-- http://dietpi.com/downloads/binaries/c2 ... _arm64.deb
--2018-08-04 17:35:05-- https://dietpi.com/downloads/binaries/c ... _arm64.deb
2018-08-04 17:35:06 ERROR 404: Not Found.
ln: failed to create symbolic link ‘/usr/local/bin/nodejs’: File exists
rm: cannot remove ‘nodejs_5-1_arm64.deb’: No such file or directory
Version actuelle :
chmod: cannot access ‘bridge’: No such file or directory
Version actuelle :
Version actuelle :
